ls crank in gsr or itr block question?
Old Sep 28, 2007 | 02:50 PM
crawlin's Avatar
Default ls crank in gsr or itr block question?
im putting ls crank and rods into my gsr shortblock is there anything specific i need to use in the gsr block from the ls block?
ive searched and have gotten mixed answers
Old Sep 29, 2007 | 05:34 AM
spooledex's Avatar
Default Re: ls crank in gsr or itr block question? (crawlin)
That should be it, because you are going to have to use the gsr pickup and pan. Just use the bearings for a ls though because the rods are different.
Old Sep 29, 2007 | 10:33 AM
crawlin's Avatar
Default Re: ls crank in gsr or itr block question? (spooledex)
i knew there was something else i needed, the bearings my builder would know anyway but its good to know just in case.
oh yeah this will most likely need to be linehoned or ?
Old Sep 29, 2007 | 08:36 PM
dude_123's Avatar
Do not align hone when you have matching main caps from the block you are going to put in. Chances that you will run into problems with the oil pump/main seal not lining up to the crank. If your bearing clearance doesn't come up to your liking, size them up using different size OEM bearings.
Old Sep 29, 2007 | 09:25 PM
all-mtr-teg's Avatar
Just finished my build, heres the thread w/ some info
https://honda-tech.com/zerothread/1837872
Old Oct 30, 2007 | 09:39 AM
bdubsol's Avatar
crawlin, i am interested in your turbo kit. i am still a trial user so i cant do sh*t on this site. email me. im very interested.
Endthisday123@hotmail.com
xrated1
Aug 15, 2009 11:21 AM
absoluteacura
Aug 1, 2008 09:26 AM
boostd ls
Mar 6, 2008 02:02 PM
jordan2305
Dec 25, 2007 05:25 PM
aser1z
Jul 28, 2005 06:47 PM
