lowering a crx?
i really need to lower my 91 crx si. i found some skunk2 coilovers for $245 shipped. what do you all think about skunk2. if i get skunk2 coilovers will i run into any problems. should i get new shocks. what all do i need to lower my car other then the coilovers.
my crx zc swap: http://www.ofoto.com/BrowsePhotos.js...id=41572422303
I've had skunk2's on my car for a year and a half with no problems. If you use stock struts, they will prematurly go bad because of being in a semi compressed state all the time. Replacing the struts is up to you at this point. You can use the ones you have until the go bad or replace them now. Other then that, you may want to consider a camber kit if you plan on lowering your car more then 1.5".
