lots of problems. Take a look please!
Old Jun 21, 2002 | 05:23 PM
b16supertuner's Avatar
Default lots of problems. Take a look please!
k from the begining. 2000 civic si
i had a jackson last fall, good kit. i was sitting in a parking lot and all of a sudden the idle dropped and it started running like ****, low idle, hesitation, and boggy. i pulled the plugs and it looked like cylinder 4 had no fuel. it didn't, i pulled the injectors, had them bench tested, all were fine, tested the injector wires for signal, all were fine. i never threw a code ????????? i didn't want the jackson anymore so i pulled it off, and kinda hoped that the engine funk was caused by the jackson electronics. i put it back together more stockish, fired it up, same problem, no fuel in cylinder 4, the plug is totally clean, no signs of combustion. this time i threw codes, code 72 and 74. misfires in cylinders 2 and 4. and the CEL blinks when the car runs.
If you have any input, it would be great.
Thanks.
-Pete
Old Jun 21, 2002 | 06:57 PM
BreakStuff's Avatar
New User
Default Re: lots of problems. Take a look please! (b16supertuner)
If you are absoulutely positive no fuel is reaching the #4 cylinder then take the most logical approach.. I would believe the injectors are receiving signal since no code for the fuel injection system is being stored...
assuming the #4 injector is firing, fuel is being fed into the intake, intake valves open allowing fuel to enter the combustion chamber.. you must determine if these valves are opening allowing fuel to enter.. I have seen egr deposits as thick as tar restrict(not completly block) fuel flow via the manifold ports but wouldn't suspect it in your case cause your car is fairly new..
Take of the valve cover and check the operation of the #4 valves while manually rotating the motor..this may give you a clue..
Another idea would be to take carb cleaner and spray directly into the intake to free up any carbon deposit buildup you may have.. and possibly any stuck valves.. Intake manifolds are shaped the way they are to create the most effecient "vortex" of air/fuel mixture and any restriction could mess up that mixture.. its a slim chance but may be worth the small effort..
[Modified by BreakStuff, 11:05 PM 6/21/2002]
Old Jun 21, 2002 | 07:11 PM
91crx but i heard vtec's Avatar
if ur check engine light is falshing u are throwing a code if u get a book on ur car it would tell u what the problem is like for a certain car say ur cel flashes 2 times slow and 4 times fast then ur throwing code 24 u may also be trowing more than one code so i would check to see waht code ur throwing and go from there i know in the 97 integra gsr there is a jumper on the passenger side that u have to have a wire go in to to jump the ecu to make the cel light flash but the si may be a little different good luck any other ? or not sure what i mean let me know i will try to help the best i can
Old Jun 22, 2002 | 05:17 AM
Chiovnidca's Avatar
The CEL blinking while the engine runs means that there is a catalyst damaging misfire in progress. Usually a problem with the secondary side of the ignition system.
zeeko
Apr 1, 2018 04:23 PM
Derek Pierson
May 25, 2013 12:45 AM
hybrid_vtec
Apr 28, 2006 09:47 AM
Tegra
Aug 30, 2004 05:08 AM
acqua20
Jul 16, 2002 07:52 PM
