Loss of power with v-tec
Set up
88 CRX si
b16a PR3 ECU
Fields sfc controller
I have on code 17 for vss no other codes, and the Fields kicks in the v-tec
when it does there is a loss of power
the A/F gauge says the fuel is rich when the v-tec crosses over..
any ideas on why?
thanks
88 CRX si
b16a PR3 ECU
any ideas on why?
thanks
Maybe because you keep putting a dash in VTEC.
Seriously, its probably because the feilds forces the car into VTEC, but the ecu is still running on the low cam ignition map. I have no idea why youre running rich though.
I did not know that the ignition map changes...
sounds like I should tackle this vtec issue after the vss issue is fixed then..
thanks.. for the info
nkcalvert09
Jun 11, 2011 10:43 PM
