LF b16-EK swap help
Old Feb 13, 2011 | 02:27 AM
khoolie's Avatar
Default LF b16-EK swap help
Hey guys. I'm new to honda, I guess I'll get to the point as quick as I can.
I bought a 99 4door civic. Bone stock. 2 weeks later the stock motor blew. I fell ***-backwards into a deal I couldn't refuse for a complete b16 swap that came out of a 97 civic. I don't know much about the swap other than its supposed to be a direct drop in sense everything came out of an EK. The block says b16a and the production date is 93 iirc, but the head has a red valve cover and it looks like an original type r valve cover not a diy job, so I think it might have a type r head especially since the ecu says b16b type-r in yellow marker.
I pulled my old motor, installed the b16. Everything was smooth and straight forward. It cranked on the first try but the fuel pump wasn't coming on so I hardwired the fuel pump to the ignition coil fuse and it started right up. Sounds good so far?
Problems:
-the alarm I had previously installed doesn't work properly. Its arms and lock but the remote start doesn't work and the automatic turn-off and alarm activation upon closing the door after removing the key doesn't work.
-the speedometer and tach on my cluster don't work, I plugged in another cluster to check and it was the same issue so I know its not my cluster. the fuel and temp gauge are fine tho.
-im pretty sure the vtec isn't working. Its pulls pretty nice all the way but I don't clearly hear a "crossover" or sudden blast of power
-there an extra plug from the engine harness and no spot for it to plug into the ecu
This is all I can think of for now. If u need pics of specific things to help diagnose my problems, just let me know and I'll post em asap.
Thanks guys!
Old Feb 14, 2011 | 11:20 PM
khoolie's Avatar
Default Re: LF b16-EK swap help
bump
any help or advice is greatly appreciated!
thanks guys
Old Feb 15, 2011 | 04:38 AM
kyden's Avatar
do you have the right engine harness?
Old Feb 15, 2011 | 11:24 AM
netfreak's Avatar
You might be running an OBD2A ECU in your OBD2B car. If your car is a 99 it should run the square shape OBD2B ECU. If you're using the rectangle shape OBD2A ECU I think you need to convert the harness.
Old Feb 16, 2011 | 01:04 AM
khoolie's Avatar
your correct. Its rectangle, not square like the original ecu that came with the car. i was thinking of trying to find a 99-00 SiR ecu? will it even work with a b16a engine?
Old Feb 16, 2011 | 01:05 AM
khoolie's Avatar
i have no idea. im brand new to honda. is there any identifiers to tell which harness i have?
Old Feb 16, 2011 | 09:34 AM
netfreak's Avatar
This is what you need to keep using the ECU you have:
http://www.xenocron.com/obd2b-to-obd...ess-p-172.html
The other alternative is to get a compatible OBD2B ECU. I happen to have an OBD2B square ECU for a B16A if you want to go that route.
MGHatch
Jan 13, 2019 05:32 PM
brett1986
Nov 18, 2015 02:03 PM
JDMhonda1919
Engine Management and Tuning
Mar 22, 2009 09:04 PM
