knock sensor/vtec question
Old Apr 7, 2005 | 10:23 PM
dryhopsux13's Avatar
Default knock sensor/vtec question
i have a 92-95 jdm b16 swap in my 96 coupe. Im running a p30 ecu. I am not running a knock sensor, and i dont get any check engine codes for it. But on the other hand....i do get a code 21 (vtec selenoid) I was wondering if the knock sensor and vtec are related, or if me not running a knock sensor would cause me to not have vtec and to throw a vtec code?
Old Apr 7, 2005 | 10:26 PM
Kendall's Avatar
Hmmm...
Double check your wiring and double check the code. Throwing either a knock sensor code, or a solenoid code will prevent the motor from switching to VTEC.
Old Apr 8, 2005 | 06:02 AM
gSIr's Avatar
Default Re: knock sensor/vtec question (dryhopsux)
Do you have your vtec changed in anyway, for example a vafc? If it is changed a significant amount from the stock setting it will cause a vtec solenoid code. The ecu thinks the solenoid is malfunctioning and activating at a different rpm.
ntoxicatedtigah
Jun 24, 2009 02:56 PM
salman
Nov 18, 2008 05:27 AM
user 72830283
Oct 16, 2005 08:24 AM
Raunch
Nov 8, 2003 10:05 PM
