knock sensor help
Old Sep 5, 2005 | 10:27 AM
sexyblack93lude's Avatar
Default knock sensor help
ok i have searched for this but no answer, im doing a b16 swap in a 91 teg i know where the knock sensor is im goin to us the plug that is not used from the ls harness to plug into the knock sensor the only problem is that plug has 2 wires a black one and a white one i dont know what wire to use not sure if it matters thinking the white one but want to be sure thanks
Old Sep 5, 2005 | 10:55 AM
rev-speed's Avatar
i think u have the wrong sensor
i don t recall any knock sensors with two wire
Old Sep 5, 2005 | 11:21 AM
Katman's Avatar
Default Re: knock sensor help (sexyblack93lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexyblack93lude &raquo;</TD></TR><TR><TD CLASS="quote">ok i have searched for this but no answer, im doing a b16 swap in a 91 teg i know where the knock sensor is im goin to us the plug that is not used from the ls harness to plug into the knock sensor the only problem is that plug has 2 wires a black one and a white one i dont know what wire to use not sure if it matters thinking the white one but want to be sure thanks
easy solution.
Simply interwine both wires so it becomes 1 wire, then wire directly to the knock sensor pinout at your ecu plug. This will ensure that either pin will be making contact with the single pin inside the knock sensor.
Old Sep 5, 2005 | 11:48 AM
rainforest's Avatar
Default Re: (rev-speed)
Do you just have the plug and 2 small strands of insulated wire on it and you want to connect to the plug to the knock sensor and then install the wire from the plug to the ecu? If thats what you are saying you can just check continuity to the wires from the end of either wire to the knock sensor the one that will have continuity to the wire that is coneccted to the ks. you could acually check the wire to any part of the back of the block and it will have continuity. or you could just wind them both like katman said it wont hurt just more wire to solder/connect
Old Sep 5, 2005 | 12:01 PM
Default Re: (rainforest)
the knoxk sensor is 1 plug but the plug im using that fits on it has two wires coming out of it, but i only use one wire to urn to the ecu pinout i think i intertwine them but not sure
Old Sep 5, 2005 | 12:02 PM
Default Re: (sexyblack93lude)
hasnt anyone done this in the past
Old Sep 5, 2005 | 12:10 PM
rainforest's Avatar
check the continuity from the engine block/knocksensor to the end of each wire. the wire that has continuity is the one you will use because it is plugged in to the knock sensor wich is plugged into the block.
Old Sep 5, 2005 | 03:00 PM
interwined them let u know if it doesnt work dont see why it wont though
Old Sep 7, 2005 | 12:31 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sexyblack93lude &raquo;</TD></TR><TR><TD CLASS="quote">hasnt anyone done this in the past</TD></TR></TABLE>
yes, I have, hence my suggestion to intertwine the 2 wires together.
4gencivicef9
Jul 27, 2006 08:31 AM
sexyblack93lude
Sep 5, 2005 05:22 PM
Boarderx192
Aug 13, 2005 12:10 PM
T_Rex
Feb 3, 2003 07:43 PM
