k&n breather
Old Jul 3, 2002 | 11:34 AM
maggsgsr's Avatar
Default k&n breather
I installed my Ice box,I misplaced the hose for my breather going from my valve cover.I replaced it with a K&N breather.I was told the motor does not properly breath with this filter any info on this?
Old Jul 3, 2002 | 11:44 AM
Spade's Avatar
Default Re: k&n breather (maggsgsr)
it just isn't smog legal in some states.......You did place the breather on the valve cover correct?
Old Jul 3, 2002 | 11:57 AM
erniecars's Avatar
Yes it is true the head will not breath well with those stupid filters. They also get oil soaked if you rev high because oil shoots out of that hold. You need the tube that connects to the intake on there to keep air flowing. Ive seen pcv valves go bad a lot faster without proper ventilation flow. Just get a replacement hose at pep boys or something or use a piece of fuel hose. If you are still going to use that crappy filter make sure you plug the nipple the hose used to go to on the intake.
Old Jul 3, 2002 | 12:46 PM
maggsgsr's Avatar
Default Re: k&n breather (erniecars)
Thanks guys.I plugged the hole on the intake.But thanks again,I'm gonna stop at pep boys ASAP.
Old Jul 3, 2002 | 09:39 PM
bryant's Avatar
The K&N one doesnt take heat to well either. it usally gets a big crack on the rubber connecting part.
92civicx
Oct 17, 2007 06:27 PM
65coupe
Jan 15, 2005 04:51 AM
kriptik
Jan 11, 2005 12:35 PM
D21X
Oct 12, 2003 08:37 PM
ActiveAero
Jan 31, 2002 01:48 PM
