Just installed a clutch and have a problem
i just installed a centerforce dual frciction clutch into a 1994 civic ex and was drinving it for the first time since the install and it was grabbing fine and everything until about 2 miles its just wouldnt go anywhere you can put it in gear without the clutch in i didnt bleed the clutch yet is that what i need to do? the rod to the thorw out bearing is ingaging becuase you can see it moving and you can hear the bearing going in and out and help would really be apprecated thanks
justin
justin
well i looked under kneeth and saw that the drivers side axle is out and i put it in and than drove it and it worked but than the abs light came on and its stoped again we are using 92 cx axels but before doing the clutch job he had 94 ex one s which were ment for his car so im assuming thats the problem?
put the ex axels back in, if you dont have that axels all the way in the tranny then you cant get into gear . Just replace the axels and you should be allright.
thanks alot im almost sure thats it because when i went under the car and push the axle all the way in it dosent click it just goes in and i can pull it out with out any pressure
Frozen E
May 7, 2006 05:40 PM
