jumpy throttle?
Old May 10, 2011 | 02:11 PM
silverdcteg's Avatar
Default jumpy throttle?
recently i decided to finally ditch my sticking throttle body with another i had in my garage. swap them out and the idle sky rocketed so i switched back to the original no problem. a few days pass and now when i start to get going(mostly at low mph 1st, 2nd) the throttle starts jerking the car like its not getting air. my friend says its possible that the map sensor is reading an untrue value so i should swap it. so i fix the other throttle body i have and put it on with a different sensor and all. still the same problem. no CELs. im stumped. motor is a lsv, type r intake mani, ls throttle body
Old May 10, 2011 | 06:15 PM
frankenghia's Avatar
Default Re: jumpy throttle?
Check your tps. Make sure you are at .45-.5 volts at closed throttle. Also make sure when you move the throttle (engine off, key turned to on position of course....), that the reading smoothly increased to about 4.5 volts wide open throttle I believe it is.. Check that. The other tb sounds like it had a vacuum leak when you hooked it up.
Old May 10, 2011 | 06:28 PM
i dont think it'd be the tps since it is two different ones that werent removed from their respective t/b but ill look into it. thanks
Old May 10, 2011 | 06:32 PM
10psiLsEf2's Avatar
tps
Old May 10, 2011 | 07:21 PM
WickedSol's Avatar
TPS...Recalibrate it... .4V-.6V closed, 4.5V-4.8V wot. GL!
Old May 11, 2011 | 07:46 AM
i still think its that. Just because you used a different tb doesn't mean its calibrated correctly. check for vacuum leaks also..
Old May 11, 2011 | 01:14 PM
thanks guys. going to check it out soon
Old May 13, 2011 | 05:04 PM
so ive been roughing it the past few days and finally a cel. 43(obd1) fuel system. the car has a new walbro(feburary). i just changed the fuel filter with an autoparts store one after the cel. starts up much better now(had been taking 15 seconds or so) but still seems to be screwy. now im thinking poor gas is a possiblity
Old May 14, 2011 | 03:34 PM
Bumppp any ideas
Old May 15, 2011 | 08:54 AM
problem solved. fuel line connected to the pump started shreading. gas was leaking back into the tank and not feeding the motor
Old May 15, 2011 | 12:57 PM
pcguy760's Avatar
Wow... interesting find.
Old May 16, 2011 | 07:30 AM
good find. thanks for posting the results.
integratyper1990
Jul 16, 2009 12:19 PM
turboef90
Mar 23, 2009 10:07 AM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
Des9255
Oct 24, 2005 09:58 PM
