JE pistons...???
my buddy has a set of new JE 81mm pistons...there are for a GSR 94-00...
will they work in my 95 LS(b18b)
i think all B series are the same...thanks alot!
The only difference is the valve pockets on the intake side are slightly larger in diameter. The pistons will yield a slightly higher compression ratio in a ls block than they would in a gsr block.
