JDM Final Drive Installed, TRANNY TECH NEEDED *HELP*
Old Feb 24, 2004 | 03:48 PM
TyPe_R_GuY's Avatar
Default JDM Final Drive Installed, TRANNY TECH NEEDED *HELP*
Okay just installed the JDM Final Drive, Went for the first start up and TROUBLE!!...
Okay when I start the car (clutch pressed in) and I let out the clutch (in neutral) it automatically kills my motor. AND when I put it in 1st,2nd,3rd,4th, or 5th gear and let out the clutch, it makes a weird scratching sound at first, then kills the motor once fully released. AND another thing is that it WONT go into Reverse AT ALL!!
If any of you tranny TECH peeps can give me an idea of what may be the problem, this would be VERY appreciated.
Old Feb 24, 2004 | 07:24 PM
Dan GSR's Avatar
Default Re: JDM Final Drive Installed, TRANNY TECH NEEDED *HELP* (TyPe_R_GuY)
i replied in ur itr forum post
also, are you using a helms?
the syncro rings go back in a very specific way, they will fit in the wrong way, but will not work properly unless put back in the right way
shoklid
17
May 7, 2009 07:56 AM
dartdc97
Oct 11, 2007 10:54 AM
TyPe_R_GuY
Feb 25, 2004 09:53 PM
ITR RACER
Aug 10, 2003 08:01 AM
