JDM 4.7 final drive info
Old Jun 4, 2002 | 12:05 AM
BigAl's Avatar
Default JDM 4.7 final drive info
can someone help with a list of the parts and part numbers that i will need to convert my 96 JDM type r g/box from 4.4 to 4.7?
thanks
Old Jun 4, 2002 | 03:58 AM
il8apex's Avatar
New User
Default Re: JDM 4.7 final drive info (BigAl)
Does a Honda 4.7 final drive exist? The only one I've ever heard of is from Jamie Houseman. He'll make you a 4.73 for D-series motors for about $1100. Doesn't do you any good, though...
If you currently have a 4.4 final drive, it should be a 16 tooth pinion with 71 tooth ring gear (yeilding 4.437). A 4.73 would be a 15 tooth pinion with 71 tooth ring gear.
Did this combination ever come out of a Honda factory?
-Tom
Old Jun 4, 2002 | 05:29 AM
J28S's Avatar
New User
Default Re: JDM 4.7 final drive info (il8apex)
Yes it does exist. It is called the JDM 4.785 Final Drive. As for the part number, have no clue. But I know a great company you can buy one from at a hell of a price. http://www.RandDMotorsports.com
Old Jun 4, 2002 | 06:34 AM
il8apex's Avatar
New User
Default Re: JDM 4.7 final drive info (J28S)
That would be a 67 ring / 14 pinion, right? (4.786)
-T
Old Jun 4, 2002 | 06:48 AM
Daemione's Avatar
They came in the JDM DC2-R.
The easiest way to do it is probably just to pick up an entire JDM Type R gearbox. May be expensive, but not much (if any) more than the labor needed to swap a FD in your tranny.
oacrep1
Mar 9, 2008 04:32 PM
Apex i ITR
Jan 16, 2002 03:35 PM
DelsolVtec18
Sep 27, 2001 01:14 AM
