i'm planning on trading my BBK 70MM TB for an ITR one. however, I have a GSR and the throttle cable on a GSR TB pulls from the opposite side that a b16/b18c5 TB does.
what will I need to be able to use an ITR tb on my stock GSR IM? where would I put the throttle cable bracket? anyone done this? thanks!
you will need gsr throttle cable bracket and pulley
i have all my stock GSR TB parts, (and the GSR TB).
but the cable pulls from the opposite direciton in ITRs (mounted on teh intake manifold itself) whereas on the GSR it pulls from a bracket mounted on the TB.
do you not know what to do with the parts i told you that you'll need?
i know what you're takling about. i'm not stupid.
if i used a GSR throttle bracket, it would not pull from the right direction. the GSR throttle bracket pulls from this direction
O
as opposed to the ITR throttle bracket which pulls from this direction
__
O
which is why you can't just use the GSR bracket.
[Modified by dLo GSR, 2:20 PM 9/1/2002]
O
__
O
You need to put the BRACKET and PULLEY on the ITR throttlebody.you will need gsr throttle cable bracket and pulley
it won't pull from the right direction.you will need gsr throttle cable bracket and pulley
and i'm assuming by pulley you mean cable. if not please show me what yu're talking aboutl.
why do you think i had to do this with my BBK:
WHen i say pulley, i mean pulley. If i meant cable i'd say cable.
DO you know what a pulley is? Its that thing thats on the throttlebody that you
put the cable on.
put the cable on.
put the cable on.
well in that case... it still won't work. you CAN'T pull the valve from any direction. i had to make a mount for the BBK so that it would pull from the right direction. the ITR TB pulls from the RIGHT SIDE, so you can't use the bracket.WHen i say pulley, i mean pulley. If i meant cable i'd say cable.
put the cable on.
stop being an *** if you're not going to help.
Im sorry that you dont know what you are doing and cant seem to grasp this
simple concept. We do this all the time, its quick and easy.
One last time for your sake:
CHANGE THE THROTTLE PULLEY AND INSTALL THE GSR BRACKET.
well i'm sorry you're being an ******* and condescending because i don't have oyu elvel of knowledge.
you say pulley and bracket. what you call pulley i call bracket. so now i dont know what you think a bracket is, so explain.
cable mount?
i see three pieces. the throttle body, the bracket (what you call pulley) that is bolted onto the TB and holds the cable. then there's the cable. what else is there?
The bracket HOLDS the cable.
The PULLEY is what the cable pulls on to open the throttlebody
ok, i understand waht you mean now. i called that the valve =P
they are interchangable?
what the.... the VALVE???
Yes, they are ALL interchangable.
valve, because when i was working on my friend's, he referred to it as a butterfly valve, and from that he just used "valve" to refer to the spring assembly / pulley / whatever.
anyway, what's the process in taking htem off and replacing them?
remove nut
remove pulley
install new pulley
tension return spring
reinstall nut
remove pulley
install new pulley
reinstall nut
sorry to be redundant but is this is all i will need to do to be able to use the ITR TB on my gsr? just want to make sure i have everything set before i go off trading TB's.
yeap. like i said, all you need is the bracket(pulley) and pulley(valve) off your
original GSR throttlebody. Hell, I could trade you an ITR tb with all the work done
for you already.
for you already.
for you already.
for my BBK 70MM?yeap. like i said, all you need is the bracket(pulley) and pulley(valve) off your
for you already.
wow dlo gsr, your a fu(king idiot.
that was entertaining
same to you, arrogant ************. all it was was term confusion. go troll somewhere else.wow dlo gsr, your a fu(king idiot.
