itr 5 lug conversion on ek PROBLEM. brakes doesnt work and doesnt have presure.
Old Aug 31, 2007 | 01:18 AM
projektCRX's Avatar
Default itr 5 lug conversion on ek PROBLEM. brakes dont build pressure
i just picked up a 5 lug conversion for my ek. everything bolted right up. bled the brakes and still wouldnt get any pressure. is there a special way in doing this. what am i doing wrong.
thanks
Modified by projektCRX at 12:15 PM 8/31/2007
Old Aug 31, 2007 | 03:17 AM
projektCRX's Avatar
Default Re: itr 5 lug conversion on ek PROBLEM. brakes dont build pressure (projektCRX)
found a leak at the master cylinder. WEAK. i still would like to know the correct process, whether it be left front, right front, left rear, right rear or what not.. thanks again.
Old Feb 14, 2008 | 08:13 AM
k20rex's Avatar
i just did 5 lug yesterday on my ek and i also have no preasure, i can not find any leaks, i'm searching for answers
Old Feb 14, 2008 | 10:37 AM
hatchling37's Avatar
Correct is RR, LF, LR, RF. If you don't have hydraulic pressure, you have a problem with your master. It's the part pushing the fluid through the lines. Do you just not have a solid pedal? Or is it spongy? Or what? Did you check the calipers to make sure the pistons are actually driving?
I think that you just need to bleed them properly, but without knowing full well what's happening, I can't make an accurate
Pworld925
Suspension & Brakes
Mar 11, 2009 09:43 PM
civictyper99
Aug 22, 2006 11:35 PM
sleepyboy
Suspension & Brakes
Jul 10, 2006 09:44 PM
eksleeper
Suspension & Brakes
Dec 21, 2005 07:41 AM
simplegreenmachine
Jan 1, 2003 09:55 PM
