integra sway bars
i have a 95 integra RS, is it worth getting 97GSR sway bars or are they the same. and if they are different will they fit? how much do u think they are worth paying for (front and rear)?
They are not the same. It is not really worth getting the GSR rear bar if you have to pay lots of money for it, it's still too small (14mm). My suggestion is get a used GSR front bar, and a rear ITR (22mm) sway bar with reinforcement brackets. IF you use a rear ITR bar with the front RS you might have too much oversteer because they won't balance the weight transfer properly.
Yeah, it'll whip right around on you if you do something stupid... but the key is to be smart.
The ITR has the same front bar as the GSR and the handling is pretty neutral, although it has stiffer springs and much stiffer shocks besides other things.
Mr.Rab
Sep 27, 2002 12:18 PM
