Installing vafc on obd0 pr3 shortly - Is this all correct?
Old Sep 25, 2004 | 05:12 AM
4_door_teg's Avatar
Default Installing vafc on obd0 pr3 shortly - Is this all correct?
Well I think I've got all except 2 wires right, what do you guys think? (I have searched here and elsewhere, just double-checking).
Purple (vtec solenoid) = A8
Pink (vtec solenoid) = A8
Yellow (vtec pressure switch) = B5
White (vtec pressure switch) = B5
Gray (Throttle signal) = C7
Black (ground) = A16
Brown (ground) = A16
Red (IG power) = A13
Orange (IG power) = A13
Now the 2 I'm not sure of are Blue (VTM signal) and green (RPM signal). I've read that green goes to the distributor ground, is that correct and if so, what # is it? Blue I have no clue where it goes, do I even need it or have a VTM signal?
Also, I will be turbo in the next month or 2 but want to get this installed and out of the way now. If I just hook this thing up what settings should I put in so that it runs pretty much like it is now? ie: I don't wanna change anything, just have it installed and out of the way. Thanks!
ef_cowboy
Apr 15, 2010 07:24 AM
fongck88
Jan 21, 2009 05:29 PM
Honda Crx
18
May 30, 2005 01:20 PM
tegsallgood
Feb 13, 2005 11:50 PM
UncleBen'sRacing
Apr 6, 2003 09:28 PM
