Injectors and resistor Boxes for swaps
I know this horse has been kicked to death but I just want to make sure of my options for a swap or if I even have any.
I have put an OBDII H22 into a 91 accord using the stock F22 engine harness. Running P13. The stock harness obviously had a resistor box and the swap came with one aswell. This is where I am getting confused. I have heard that you dont need a resistor box for 97+ H22's so why would this swap have one ? Perhaps the motor was mislabeled for the sale ?
With this swap are these my correct options for fuel ?
1. Use stock F22 injectors with resistor box.
2. Use stock OBDII H22 injectors with on resistor box.
If option 2 is indeed an option what do you do with the harness plug that would have gone to the resistor box. I have tried to start the car and it will turn over and run for 1 second then die. I am quite sure it is getting starved for fuel. Thank for any help.
Stroker
Mar 13, 2003 06:26 PM
