injector box question (injectors not squirting)
Old Dec 30, 2004 | 09:33 PM
W C L's Avatar
Default injector box question (injectors not squirting)
my question is I swapped a h22 into a 99 civic 4dr , i wired up the resistor box with only 1 power source coming from the injectors goign to the red wire instead of all 4 could this be casuing my injectors not to squirt???? yes the 4 wires coming from the injector box is hooked upcorrectly returning power to each injector, but my question is wit hteh red wire feeding the injector box
all 4 wires of the distribution block together (These wires are the one you tested in step 1) and solder the red wire to them.
i dont understand y it would need 4-12v power sources when i could use 1 do the same thing????
Old Jan 8, 2005 | 02:36 PM
turboteg2nv's Avatar
Default Re: injector box question (W C L)
Bump, cus i setup my resistor box the exact same way and my car won't start either.
Check the volts on your injector clips and let me know what your results were. I got 12v on one side, and only 3.9v on the other side. On my bro's 95 talon gsx he had 12v on both sides of the injector clip.
Old Jan 8, 2005 | 07:55 PM
W C L's Avatar
Default Re: injector box question (turboteg2nv)
u need to move the box and splice it at the main power feed distribution plug and not in the middle of the harness like we have done.... but u can use 1- 2 - 3- or 4 of the power feed wires out of the inj ...... let me know if that helped
hb_guy
May 13, 2015 02:16 PM
K7-1Ktrevor
Mar 9, 2010 07:41 PM
laxrider
Feb 17, 2008 04:51 PM
tranceologist
Aug 21, 2005 07:57 PM
Prelude Racer
Mar 8, 2004 10:10 PM
