ignition tech: MSD 6AL, what coil?
I just purchased an MSD ignition 6AL system. To make a long story short, I needed this for its soft-touch rev-limiter function.
Anyway, after researching on the compatible MSD coils, it seemed that the Blaster SS coil was made to run with the 6-series ignitions.
But I have seen many people with the Blaster 2 coils along with the 6-series. What should I be looking for and whats the difference?
If you can explain why there is a difference and what the benefits are I'd also really appreciate it.
THANKS!
THANKS!
blaster ss puts out more voltage than the 2 ... not that it will make a difference, both will work the same, you can even use your stock coil.
greg
greg
crxsiperf
Feb 18, 2005 07:01 AM
