Idle problem with h22a in EG
Old Jul 7, 2004 | 03:15 PM
aaaabbbb's Avatar
Do not purchase anything from me. -HT Staff
Default Idle problem with h22a in EG
i have an idle problem with my car... when i first start it up it idles high at like 2.5 than it goes up higher to like 3 than it starts going up and down and it goes down when its warmed up, but the idle doesnt go below 1.5.. anyone got any ideas on wut the problem may be?? i tired messing with the IAC but no help. any help would be appreciated. thanks
Old Jul 7, 2004 | 06:49 PM
Katman's Avatar
Default Re: Idle problem with h22a in EG (H22AEG)
are you getting any check engine lights? and what ecu are you running?
if you're running an OBD1 P13 ecu, I bet it has something to do with code 12 (EVAP or EGR, I always get those 2 confused)
Old Jul 7, 2004 | 10:38 PM
rev-speed's Avatar
check ur cold start up idle air control valve
its mounted under ur throttle body
its a common thing
Old Jul 7, 2004 | 11:32 PM
92bubblesi's Avatar
I don't know about the H22 but I had a similar prob with my D16Z6 and it was the IAC. I took it apart and found that there was a plastic peice that is threaded and had backed it self out. I would take it apart and see if every thing looks good.
Old Jul 8, 2004 | 12:51 PM
aaaabbbb's Avatar
thanks for the info.. i gotta go test everything out.. im using a p28 ecu with hondata, no check engine light just idles high
Old Jul 8, 2004 | 01:17 PM
pgpunkguy's Avatar
Default Re: Idle problem with h22a in EG (speedjunkiez motorworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedjunkiez motorworks &raquo;</TD></TR><TR><TD CLASS="quote">how bout the tps sensor.. is it reading the right voltage.. ???</TD></TR></TABLE>
tps sensor...
redundant?
Sir_LagaLot
Jul 30, 2016 11:19 AM
91dxhatch
Jan 4, 2007 11:46 AM
Terrible One
Apr 6, 2006 04:51 PM
worrdogg
Nov 4, 2004 12:16 PM
Hondaaccordvtec
Apr 7, 2003 08:15 AM
