Humming/Whining noise.. while turning left or right.
Old Mar 27, 2008 | 08:30 PM
djdownfawl's Avatar
Default Humming/Whining noise.. while turning left or right.
03 Civic 1.7l Coupe
Problems:
When the car is stationary and started up, i turn the steering wheel from center position to the right or left position there is a Humming/Whining noise that comes from IDK where???
And it gets louder as the steering wheel approaches to the far left or right.
Please help!! This is really bothering me.
And now recently when the car is started up and stationary and i make it go to about 4-5k RPMs there is a rapid ticking sound from under the hood.
I don't know whats going on!! PLEASE HELP!!
Old Mar 28, 2008 | 01:01 PM
JDM Lyfestyle's Avatar
Default Re: Humming/Whining noise.. while turning left or right. (djdownfawl)
Check your PS fluid its probably low and your pump may well be going out
Old Mar 28, 2008 | 06:38 PM
96Spec Ek's Avatar
Put some power steering fluid in.
Old Mar 29, 2008 | 10:15 AM
djdownfawl's Avatar
Default Re: Humming/Whining noise.. while turning left or right. (96Spec Ek)
Power steering fluid is enough in the reservoir.
Its upto the upper level.
Old Mar 30, 2008 | 02:24 PM
start the engine and then open the resovoir..see if the fluid is bubbling or just sitting still..is it hard to turn at all?
Old Mar 31, 2008 | 10:17 AM
Andy M's Avatar
Default Re: Humming/Whining noise.. while turning left or right. (JDM Lyfestyle)
I had a similar problem. I thought it was a noisy pump, so I replaced it and the noise was still present. Several mechanic friends have now told me it's most likely a bad steering rack introducing air to the system.
As JDM L. said, look in the PS. reservoir. If the fluid is foamy, your pump is sucking air from somewhere. The rack is commonly the culprit.
CheezeFrog
Nov 18, 2019 11:11 PM
Kevin Jung
Honda Civic (2001 - 2005)
Feb 19, 2016 08:28 AM
questseek
Mar 6, 2010 09:32 PM
Inextricabledrvr
Mar 18, 2009 07:56 PM
djdownfawl
Mar 26, 2008 08:24 PM
