How safe to downshift a B20-VTEC ..........
Old Aug 21, 2002 | 08:04 AM
eg6madness's Avatar
Default How safe to downshift a B20-VTEC ..........
i have heard that if ya miss-shift a B20VTEC it can cause serious harm ( such a bent valves , etc ) ...... I was wondering how safe is it to downshift a B20VTEC and apply the power hard ......
for those of you who don't understand ....here is an example .... you are at the track on the straight speed up to 140+kph (in 3rd or 4th gear ) , approaching a hard right hand corner , you late brake and downshift on entering the corner, and start to ease brake pressure . When you release the clutch your car is near the apex so time to apply power , you flat you accelerator foot .
Can the B20VTEC take this kind of pounding ?
Can stronger valve springs help the life of the motor ?
Old Aug 21, 2002 | 08:37 AM
Spade's Avatar
Default Re: How safe to downshift a B20-VTEC .......... (eg6madness)
Just get the heal-toe down and you will be fine.
Old Aug 21, 2002 | 10:02 AM
riceboy's Avatar
Default Re: How safe to downshift a B20-VTEC .......... (Spade)
are the crv pistons stock, cause the valve reliefs arent the size of the vtec valves, under 8000 rpm, no prob, rpm is rpm, as long as it isnt over revved, you shouldnthave any probs, and yes stiffer valvesprings can and will extend the life of you motor, espicislly if you miss shifts alot.
Keep in mind this is a quick answer, since i am typing with 1 hand (LCA bolt went through right middle finger, 11 stiches and plenty of hydrocodone) but since this is a quick answer, that means thast there are many more varibles that can go into what your taling about, but, you should be fine if the motor never sees more than 8000 rpm.
Old Aug 21, 2002 | 12:50 PM
88_SC_CRX_Si's Avatar
New User
Default Re: How safe to downshift a B20-VTEC .......... (riceboy)
Hydrocodone - The breakfest of champions...
[Modified by 88_SC_CRX_Si, 1:50 PM 8/21/2002]
Old Aug 21, 2002 | 01:15 PM
nixadm's Avatar
Default Re: How safe to downshift a B20-VTEC .......... (88_SC_CRX_Si)
lol
89efhatchy
Mar 14, 2014 06:32 PM
Hatch It
May 19, 2004 01:27 PM
ALLMOTR_R
Oct 27, 2003 09:38 AM
eg6madness
44
Aug 26, 2002 06:36 AM
eg6madness
Aug 21, 2002 11:31 AM
