how to remove rear hub off 91 si?
take off the 4 lug nuts to remove the wheel. use a flat screwdriver to remove the hub cap (shiny brass lookin cap thing). then take 2 bolts to push on the drum if you cant pull it off. i don't know the dimension to these 2 bolts tho, i had a bucket of bolts. if not this, try a flat screwdriver to the edge of the drum. the hub should be viewable, and its held on with a 22mm nut torqued to 134lb-ft so thats gonna take you a big *** breaker bar to get off. remember that its staked on there, and you may need a prybar for that. this bult must be replaced upon removal as well as its washer behind it. the hub is pressed in, you may need some elbow grease to get that off.
typeeg
Jul 20, 2004 05:21 PM
