How much will jun 3 cams help my current setup(experts help)
Old Nov 6, 2002 | 08:26 AM
lazyguy's Avatar
Default How much will jun 3 cams help my current setup(experts help)
right now i have a b18c1 with skunk 2 mani, b&m fuel reg.,aem cai, toda header, 99 si tranny with clutchmaster stage 3 and clutchmaster flywheel, with a skunk 2/rsr exaust, and a jun spec ecu
im just wondering if putting in jun 3 cams will help right now or if i should wait till theres more done like higher comp and ported head
the way i figured, the cams cant hurt right?
Old Nov 6, 2002 | 08:38 AM
advanracing62's Avatar
Default Re: How much will jun 3 cams help my current setup(experts help) (lazyguy)
you'll notice a difference with the cams. They do love high compression though, but the key is air movement. You should have enough intake and exhaust movement to make things work good. One note, your JUN chipped ecm will suck after you put those cams in... Vtec is very smooth, but it almost makes you feel like you're getting nowhere, Hondata is good if you can afford it.
Old Nov 6, 2002 | 08:41 AM
lazyguy's Avatar
Default Re: How much will jun 3 cams help my current setup(experts help) (advanracing62)
i know tunning will be necessary, and the ecu isnt a real jun ecu its just a chip i got from adrian at hyperduck tunning, can anyone judge what kind of numbers i might be able to put down?
Old Nov 6, 2002 | 09:23 AM
CHEETAH's Avatar
if you've found a good deal on the set of jun cams, then hop on them and hold them for when you get some headwork done along with getting compression bumped up. The JUN as with other performance cams may hurt you more than help you as it severly reduces dynamic compression. If adding high dome pistons was not in your realm of the next yr or so, then pull the head off and mill it along wiht a thinner headgasket to at least bump up compression a bit then throw the JUN cams in.
Greg
Old Nov 6, 2002 | 09:26 AM
lazyguy's Avatar
Default Re: How much will jun 3 cams help my current setup(experts help) (CHEETAH)
thanks greg, i just wonder cuz ive seen people with toda b's on stock gsr bottom making some decent power, but i guess ill wait til i do the whole motor
GReddySiR
Nov 13, 2004 09:51 AM
GreenR
Jul 23, 2003 12:26 PM
Grocery Getter R
Jan 31, 2003 04:03 PM
YellowSpeed
Jun 11, 2002 11:03 AM
6SPD_EK
Oct 24, 2001 10:01 AM
