how to ID a B-series tranny
Old Feb 10, 2004 | 09:07 AM
BLUE EH3's Avatar
Help we my pennies
Default how to ID a B-series tranny
im planning to buy a SI or GSR tranny in a few weeks. i want to to ripped off, by buying a GSR tranny and really be buying a LS tranny. what can i do? also what should a tranny come with?
Modified by BLUE EH3 at 3:08 PM 2/11/2004
Old Feb 10, 2004 | 10:00 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: how to ID a B-series tranny (BLUE EH3)
i know alot guys want to know also! bump 4 a damn good question
Old Feb 10, 2004 | 10:35 AM
vtecb20coupe's Avatar
B A N N E D
the 99-00 si tranny's have a "s4" stamped on them.
Old Feb 10, 2004 | 12:06 PM
Kataku2K3's Avatar
Default Re: how to ID a B-series tranny (vtecb20coupe)
If you've worked with motors/trannies a lot you should just be able to see the size/shape difference... If not there are several quick things to separate a B series from a D series tranny... A D series tranny uses a little "C" shaped plate bolted to the rear of the tranny to bolt the torque rod (stabilizer bar on the linkage) to it where as a B series uses a casted in pin on the lower side... It would be a lot better to show you via pics but I don't have any trannies down at school with me...
I didn't really understand your first post, you're going to be purchasing a B16 or GSR tranny and you're swapping out the LS, correct? It sort of sounded like you were buying a LS tranny too... I really wouldn't go by what the case is stamped by as Honda didn't do a very good job labeling (i.e. one year S80 can be a GSR another year S80 can be an LS/GS/RS)... The way I normally go about finding what a certain tranny is, is opening it up and counting teeth (using the known ratios) or you can set the car in a certain gear (1st is the most accurate) and count the number of rotations over the mainshaft for one complete differential rotation... Either way works and they're the only way to be really sure... Just my $0.02
Old Feb 11, 2004 | 11:05 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: how to ID a B-series tranny (Kataku2K3)
what didnt u get?
Old Feb 11, 2004 | 11:20 AM
B A N N E D
he doesn't want to get stuck with an ls so wants to know how to identify a si or gsr tranny. correct?
and by the way, most tranny's don't come with anything.
Old Feb 16, 2004 | 12:57 PM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">he doesn't want to get stuck with an ls so wants to know how to identify a si or gsr tranny. correct?
and by the way, most tranny's don't come with anything.</TD></TR></TABLE> CORRECT!!! theydont come with sensors??
Big J EK9
Mar 26, 2009 04:38 PM
cu_jarrett
Apr 24, 2004 11:43 AM
dustrag
Jan 27, 2004 12:11 PM
jdmCivic925
Oct 20, 2003 11:07 PM
