HOW TO GET RID OF ANNOYING BREAK SQUEEK??
Old Mar 22, 2002 | 11:20 AM
timbuktu's Avatar
Default HOW TO GET RID OF ANNOYING BREAK SQUEEK??
hey guys i put on new pads last month and the car squeeks like a ****...anyways any advise would be appreciated.
Old Mar 22, 2002 | 11:38 AM
Perfectionist's Avatar
Default Re: HOW TO GET RID OF ANNOYING BREAK SQUEEK?? (timbuktu)
It may just be a normal function of the pads if you installed some really hard ones. I prefer OEM from Honda. Anyway, shims and anti squeal grease comes with the OEM pads. If you didn't use any with yours, that might explain the noise.
Old Mar 22, 2002 | 01:19 PM
REDBARON's Avatar
Default Re: HOW TO GET RID OF ANNOYING BREAK SQUEEK?? (Perfectionist)
Shims and anti-squeal. Like he said. If you didn't replace them or use any for that matter, then that could solve your problem.
Old Mar 22, 2002 | 04:35 PM
hondafrk's Avatar
Default Re: HOW TO GET RID OF ANNOYING BREAK SQUEEK?? (VTECHatch)
GREASE GREASE GREASE!!!!
You need to make sure that all the shims are in place, and also any place where the brake pad contacts a metal surface you need to have a good coating of a brake caliper grease or other silicone grease. be careful not to get any on the friction material.
Old Mar 22, 2002 | 10:53 PM
gogu's Avatar
put some oil in your master cylinder just kidding do not do this
Old Mar 23, 2002 | 02:37 AM
Lei Siew Long's Avatar
i asked the same question on here before and was told to sand the rotor, pads, and piston. it got rid of 90% of the squeaking. but, when i brake lightly, it would still squeak.
jdadams12
Aug 31, 2010 12:50 PM
HonDA INTEGRATY
Dec 5, 2008 07:22 AM
Myroslav
Jul 28, 2005 08:12 AM
Iceman05
Oct 13, 2004 05:09 PM
rus
Oct 9, 2002 01:34 PM
