how to get engine at TDC?
Old Feb 23, 2004 | 01:52 PM
bluedelsol's Avatar
Default how to get engine at TDC?
is there any way to get my block at TPC without taking off the crank pully to line up the marks. i took the head off to get the valve seals replaced and the car got moved and the engine moved so now my marks on the timing belt arnt right. and how many times can my marks match up before the timing acually right?
Old Feb 23, 2004 | 01:59 PM
infinatenexus's Avatar
Rotate the motor untill the timing mark on the crank pulley is at TDC
Old Feb 23, 2004 | 02:03 PM
bluedelsol's Avatar
Default Re: (infinatenexus)
i know that, i asked if there was any other way besides doing that, because in order to see the marks i gota take off the pully and belt cover. and i dont want to do that.
Old Feb 23, 2004 | 02:04 PM
If you have the stock pulley.. they are on the out side of it.. how else would you set your timing with a light?
Old Feb 23, 2004 | 02:08 PM
bluedelsol's Avatar
witch mark is TDC?
Old Feb 23, 2004 | 02:49 PM
McDade's Avatar
Default Re: (bluedelsol)
white
DavidCRV
Aug 26, 2013 03:12 PM
HBK
Sep 1, 2005 09:37 AM
94dxt
Oct 27, 2004 12:36 PM
JONBLAZE55555
Nov 27, 2003 12:46 PM
