how to eliminate injector resistor box.
Old Oct 23, 2003 | 05:03 PM
JBk24crx's Avatar
Default how to eliminate injector resistor box.
i need to eliminate my resistor box so that i can use my new injectors. what is needed to not run a resistor box.
Old Oct 23, 2003 | 09:18 PM
chrisCNL's Avatar
Default Re: how to eliminate injector resistor box. (rub760)
are your new injectors high impidence injectors...if they are tap all of the red/blk to the yellow/blk wire that goes into the injector resistor... disconnect the injector resistor or get a bad injector resistor and cut the wire part of the plug and connect them together and plug it up to your old harness.
Old Oct 24, 2003 | 12:43 AM
JBk24crx's Avatar
Default Re: how to eliminate injector resistor box. (chrisCNL)
yes high impidence.. thanks for the great info.
mpf90
Mar 23, 2009 11:54 AM
z6
Jun 19, 2004 06:37 PM
20lb.teg
Sep 20, 2002 09:54 AM
Alstare
May 11, 2002 09:13 AM
