how do you remove PCV?
Old Mar 3, 2003 | 09:04 AM
turbochic's Avatar
Default how do you remove PCV? should i shut off egr?
I have a 97 civic ex d16y8, read that i should replace the pcv valve about every 30,000 miles, how do you get to them to replace it?
I also heard that if you shut off or close off the egr you get increased performance. If that is true how to you do that?? Thanks
[Modified by fmaxturbochic, 10:11 AM 3/3/2003]
[Modified by fmaxturbochic, 10:22 AM 3/3/2003]
Old Mar 3, 2003 | 09:05 AM
Russ713's Avatar
dAng!
Default Re: how do you remove PCV? (fmaxturbochic)
the pcv just slides out. It just fits snug into the intake manifold.
Old Apr 7, 2006 | 08:55 PM
96accordlxf22b2's Avatar
I cursed out BauleyCivic and got banned
Default Re: how do you remove PCV? (Russ713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbochic &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 civic ex d16y8, read that i should replace the pcv valve about every 30,000 miles, how do you get to them to replace it?
[Modified by fmaxturbochic, 10:22 AM 3/3/2003]</TD></TR></TABLE>
none of that is true btw
Old Apr 7, 2006 | 10:09 PM
EnzoSpeed's Avatar
Default Re: how do you remove PCV? should i shut off egr? (turbochic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbochic &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 civic ex d16y8, read that i should replace the pcv valve about every 30,000 miles, how do you get to them to replace it?</TD></TR></TABLE>
The PCV is #3 in this pic. Follow the vacuum hose down through the front of the intake manifold. The hose ends at the PCV which is stuck into what looks like a black tuna can. To remove the PCV, just grab it and yank it out. It's only held in with pressure. It's a bitch to get at though, especially if you still have an intake manifold brace.
If you've gone 30k on the same PCV, it would be a good idea to replace, or at least check it. They get gummed up over time and the ball bearing inside tends to freeze up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> I also heard that if you shut off or close off the egr you get increased performance. If that is true how to you do that?? Thanks </TD></TR></TABLE>
That's kind of true. The EGR is both good and bad, but I don't feel the need to get into it because luckily your motor doesn't come with an EGR. You lucked out
mrprofits1
Dec 12, 2011 07:46 PM
NACE42
Mar 7, 2010 11:05 AM
CivicExMaster
Feb 17, 2008 06:06 PM
orange.honda
Apr 3, 2003 07:47 PM
