How Do I Remove The Woodruff Key On The Crank
For the love of god i cant get the key out. Any of you guys have any suggestions? Ive tried yanking on it with some pliers but its messing the key up. Please Help!
It'll slide up and out when you hammer it back. Ice the woodruff key to maybe help it to shrink a little and give you a little more clearance against the crank snout.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King-Kong »</TD></TR><TR><TD CLASS="quote">So is the crank pulley already off? If so then try to perhaps pry it up with a small tipped screw driver? If the pulley is not off for some reason take it off then work on it from there.</TD></TR></TABLE>
yeah the pulley is off. i just cant get the crank gear off because of the key.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner »</TD></TR><TR><TD CLASS="quote">heat it up with a blow torch! then tap it with a hammer. Try PB blaster as well, but dont use the PB with the torch(unless you really hate your engine ). </TD></TR></TABLE>
I think im going to go buy a little torch today and see if that solves it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by runeminaEF9 »</TD></TR><TR><TD CLASS="quote">try a gear puller if you can fit one in that area. </TD></TR></TABLE>
Cant fit one in tthere.
Ransom
Feb 15, 2006 11:09 AM
