how do i hook up a map sensor for 89 crx si?
Do you have a vacuum diagram on the hood? If not it should be hooked up to the top vacuum port on the throttle body. Not the big one, the little one.
Now from there it should go to a "T" fitting. The fitting pointing up (Upside down T)
Attach a three inch vacuum tube on both ends like this...
MAP SEN.
TB _______|_____. Capped off.
Three inches to MAP and three inches to a plug/cap.
EDIT: Well it doesn't line up when I post Hopefully you can go off the words.
Hope this helps and you can understand.
MAP SEN.
Cractos
Jan 17, 2005 03:43 PM
Ri5e
Mar 27, 2003 06:18 PM
