How Do I Bypass the Heater Core?
Old Feb 16, 2008 | 03:07 PM
dand39's Avatar
Default How Do I Bypass the Heater Core?
This is for a 1996 Honda Accord LX (F22B). I haven't used the car in about a month, and it's been parked on the street on an inclined hill. I just started it up today and pulled it into my garage, and that's when I noticed:
1) My entire driver side floorboard was soaked, and
2) Water was profusely leaking out from under my car, on the driver side.
I did a quick search a came up with heater core problems, but I'm still a bit unclear about something...
I've identified the two hoses that go into the firewall. Can I just unplug the ends that go into the firewall and loop them together, or plug them up? What should I use to loop or plug the two hoses?
Some additional questions:
1) Those hoses are ridiculously difficult to access and remove. Any advice?
2) Any alternative points that I can disconnect the hoses from? (there seems to be some points under the car that's easier to reach, compared to the firewall)
3) What size are the hoses?
Thanks for your help.
Old Feb 16, 2008 | 04:33 PM
97grnrs's Avatar
Default Re: How Do I Bypass the Heater Core? (dand39)
follow the hoses to the engine and loop them together.. u dont need to block off the ends of the core just leave them..
Old Feb 16, 2008 | 09:07 PM
GhostAccord's Avatar
Unplug the two heater hose lines from the core fittings on the fire wall. Then connect them together with one of these heater hose couplings and two hose clamps.
That's all you need to do.
dand39
Oct 3, 2012 06:59 AM
Gathers
May 13, 2010 11:23 AM
Prudz_lude
Sep 4, 2008 03:04 PM
Linh.
Aug 12, 2006 12:17 AM
na96civic
Apr 27, 2004 10:50 PM
