How do coil overs work?
Old Feb 1, 2002 | 01:18 PM
Islandboy's Avatar
Default How do coil overs work?
How do they work and how do you adjust them? can they be adjusted while they are on the car?
Old Feb 1, 2002 | 01:42 PM
Spade's Avatar
Default Re: How do coil overs work? (Islandboy)
They take the usual mounting points only have a screw type ring where the bottom of the spring rests. You adjust that while it is attached to the car.
Old Feb 1, 2002 | 02:31 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: How do coil overs work? (Spade)
Yep....basically think about how your springs and shocks sit now. The springs sit on a perch that's part of the shock.
In a coilover, the perch area is on a threaded body, so you can move it up or down.....hence the spring moves up and down....hence the car moves up and down. Hehe.
blackeg
Suspension & Brakes
Sep 9, 2011 07:35 PM
Bjorn20
Oct 16, 2005 09:19 AM
abercrombemonkey
Suspension & Brakes
Oct 1, 2005 08:23 AM
ScottEK
Dec 25, 2004 09:23 AM
lliew
Oct 21, 2001 03:02 AM
