how to convert obd-0 to obd-1?
i have an '88 b16a motor that im going to put into my '91 Si and i already have a skunk2 obd-1 p28 ecu that i had been using on my '99 Si with the obd-2 to 1 harness... is there such a harness for obd-1 to 0?
Your subject & last question dont make sense, but ya there is such thing as OBD0-to-OBD1 conversion. Its much easier than going OBD2-to-OBD1
If you don't want to search for the harness I have spliced all of the connections before, it is actually quite easy... BTW you will need a new distributor and if you are going to use the stock injectors you will need a resistor box. As well as a 4 wire O2 sensor and the corresponding exhaust pieces that it fits into. I don't know which ones that is in the Civic, for my Integra all I had to change was the exhaust manifold and downpipe.
90civicstdgold
Jul 7, 2011 03:20 PM
