Honda window malfunction ! ! need help asap !
Now I know civics are infamous for window problems so here it is....
Today as I was rolling up the passenger window and it stops half way and wont budge an inch. I pulled off the door panel and its probably safe to say its the motor/ regulator. My question is this....is there anyway I can fix the widnow so that it is closed. If the screws on the bottom on the window were accessable I could un-bolt the two and manually force it up that way but they are NOT. Anyone have any suggestions/experience with this??
I need to get this closed ASAP as I will not be one of those SQUARES with a f***in garbage bag (or any other type of bag) over my window.
MM&Y of car would help.
First thing I would try is supply power and ground directly to the motor, this will confirm if the problem is the motor or something else, if it is not the motor it will allow you to roll the window up.
If there is a problem with the motor, you will have to dismount the motor slide window up and reinstall the motor to keep the window up. 94
RGoose18
Aug 28, 2009 10:39 PM
hondaman_18
Dec 14, 2007 06:13 PM
