history of vtec and vvt.
Old Jul 19, 2010 | 09:32 PM
raverx3m's Avatar
Icon7 history of vtec and vvt.
bumped into it while gathering some info about vvt system.
thought it would be good info to read for everyone,
a lil updated from the previous threads that were made in 2001/2002.
in general:
fiat patented it, alfa romeo was first to make production car, honda made it popular
thank god for the displacement tax mentioned below, otherwise we would be driving VTEC nissans...
taken from wikipedia.
http://en.wikipedia.org/wiki/VTEC
VTEC (Variable Valve Timing and Lift Electronic Control) is a valvetrain system developed by Honda to improve the volumetric efficiency of a four-stroke internal combustion engine. This system uses two camshaft profiles and electronically selects between the profiles. This was the first system of its kind. Different types of variable valve timing and lift control systems have also been produced by other manufacturers (MIVEC from Mitsubishi, VVTL-i from Toyota, VarioCam Plus from Porsche, VVL from Nissan, etc.). It was invented by Honda R&D engineer Ikuo Kajitani. It can be said that VTEC, the original Honda variable valve control system, originated from REV (Revolution-modulated valve control) introduced on the CBR400 in 1983 known as HYPER VTEC. In the regular four-stroke automobile engine, the intake and exhaust valves are actuated by lobes on a camshaft. The shape of the lobes determines the timing, lift and duration of each valve. Timing refers to an angle measurement of when a valve is opened or closed with respect to the piston position (TDC or BDC). Lift refers to how much the valve is opened. Duration refers to how long the valve is kept open. Due to the behavior of the working fluid (air and fuel mixture) before and after combustion, which have physical limitations on their flow, as well as their interaction with the ignition spark, the optimal valve timing, lift and duration settings under low RPM engine operations are very different from those under high RPM. Optimal low RPM valve timing, lift and duration settings would result in insufficient filling of the cylinder with fuel and air at high RPM, thus greatly limiting engine power output. Conversely, optimal high RPM valve timing, lift and duration settings would result in very rough low RPM operation and difficult idling. The ideal engine would have fully variable valve timing, lift and duration, in which the valves would always open at exactly the right point, lift high enough and stay open just the right amount of time for the engine speed in use.
VTEC was initially designed to increase the power output of an engine to 100 PS/liter or more while maintaining practicality for use in mass production vehicles. Some later variations of the system were designed solely to provide improvements in fuel efficiency, or increased power output as well as improved fuel efficiency. In practice, a fully variable valve timing engine is difficult to design and implement.
The opposite approach to variable timing is to produce a camshaft which is better suited to high RPM operation. This approach means that the vehicle will run very poorly at low RPM (where most automobiles spend much of their time) and much better at high RPM. VTEC is the result of an effort to marry high RPM performance with low RPM stability.
Additionally, Japan has a tax on engine displacement, requiring Japanese auto manufacturers to make higher-performing engines with lower displacement. In cars such as the Toyota Supra and Nissan 300ZX, this was accomplished with a turbocharger. In the case of the Mazda RX-7 and RX-8, a rotary engine was used. VTEC serves as yet another method to derive very high specific output from lower displacement motors.
different versions of vtec engines
DOHC VTEC
SOHC VTEC
VTEC-E
3-Stage VTEC
i-VTEC
K-series
R-series
i-VTEC VCM
i-VTEC i
AVTEC
VTEC in motorcycles
VVT timeline
http://en.wikipedia.org/wiki/Variable_valve_timing
Aircraft
Some versions of the Bristol Jupiter radial engine of the early 1920s incorporated variable valve timing gear, mainly to vary the inlet valve timing in connection with higher compression ratios.[2] The Lycoming R-7755 engine had a Variable Valve Timing system consisting of two cams that can be selected by the pilot. One for take off, pursuit and escape, the other for economical cruising.
[edit] Automotive use
Fiat was the first auto manufacturer to patent a functional automotive variable valve timing system which included variable lift. Developed by Giovanni Torazza in the late 1960s, the system used hydraulic pressure to vary the fulcrum of the cam followers (US Patent 3,641,988). The hydraulic pressure changed according to engine speed and intake pressure. The typical opening variation was 37%.
In September 1975, General Motors (GM) patented a system intended to vary valve lift. GM was interested in throttling the intake valves in order to reduce emissions. This was done by minimizing the amount of lift at low load to keep the intake velocity higher, thereby atomizing the intake charge. GM encountered problems running at very low lift, and abandoned the project.
Alfa Romeo was the first manufacturer to use a variable valve timing system in production cars (US Patent 4,231,330). The 1980 Alfa Romeo Spider 2.0 L had a mechanical VVT system in SPICA fuel injected cars sold in the United States. Later this was also used in the 1983 Alfetta 2.0 Quadrifoglio Oro models as well as other cars. The system was engineered by Ing Giampaolo Garcea in the 1970s.[3]
Honda's REV motorcycle engine employed on the Japanese market-only Honda CBR400F in 1983 provided a technology base for VTEC.
In 1986,[citation needed] Nissan developed their own form of VVT with the VG30DE(TT) engine for their MID4 Concept. Nissan chose to focus their NVCS (Nissan Valve-Timing Control System) mainly on torque production at low to medium engine speeds, because, the vast majority of the time, automobile engines will not be operated at extremely high speeds. The NVCS system can produce a smooth idle and high amounts of torque at low to medium engine speeds. The VG30DE engine was first used in the 300ZX (Z31) 300ZR model in 1987. It was the first production car to use electronically controlled VVT technology. In 1987 Nissan also sold the Gloria, Leopard, and Cedric, all of which could come powered by the VG20DET engine which also utilized Nissans NVCS valve timing system.
The next step was taken in 1989 by Honda with the VTEC system. Honda had started production of a system that gives an engine the ability to operate on two completely different cam profiles, eliminating a major compromise in engine design. One profile designed to operate the valves at low engine speeds provides good road manners, low fuel consumption and low emissions output. The second is a high lift, long duration profile and comes into operation at high engine speeds to provide an increase in power output. The VTEC system was also further developed to provide other functions in engines designed primarily for low fuel consumption. The first VTEC engine Honda produced was the B16A which was installed in the Integra, CRX, and Civic hatchback available in Japan and Europe. In 1991 the Acura NSX powered by the C30A became the first VTEC equipped vehicle available in the US. VTEC can be considered the first "cam switching" system and is also one of only a few currently in production.
In 1991, Clemson University researchers patented the Clemson Camshaft which was designed to provide continuously variable valve timing independently for both the intake and exhaust valves on a single camshaft assembly. This ability makes it suitable for both pushrod and overhead cam engine applications.[4]
In 1992, Porsche introduced VarioCam its 968 model which provided continuously variable valve timing for the intake valves.
In 1992, BMW introduced the VANOS system. Like the Nissan NVCS system it could provide timing variation for the intake cam in steps (or phases), the VANOS system differed in that it could provide one additional step for a total of three. Then in 1996 the Double Vanos system was introduced which significantly enhances emission management, increases output and torque, and offers better idling quality and fuel economy. Double Vanos was the first system which could provide electronically controlled, continuous timing variation for both the intake and exhaust valves.
Ford began using Variable Cam Timing in 1998 for the Ford Sigma engine and the Ford Zetec engine. Ford became the first manufacturer to use variable valve timing in a pickup-truck, with the top-selling Ford F-series in the 2004 model year. The engine used was the 5.4 L 3-valve Triton.
In 1999, Porsche introduced VarioCam Plus on its 911 Turbo which combined continuous valve timing and two stage valve lift on the intake valves.
In 2001, BMW introduced the Valvetronic system. The Valvetronic system can continuously and precisely vary intake valve lift, and in addition, the independent Double VANOS system can concurrently vary the timing for both the intake and exhaust valves. The precise control the system has over the intake valves allows for the intake charge to be controlled entirely by the intake valves, eliminating the need for a throttle valve and greatly reducing pumping loss. The reduction of pumping loss accounts for more than a 10% increase in power output and fuel economy.
In 2005, General Motors offered the first Variable Valve timing system for pushrod V6 engines, LZE and LZ4.
In 2007, DaimlerChrysler became the first manufacturer to produce a cam-in-block engine with independent control of exhaust cam timing relative to the intake. The 2008 Dodge Viper uses Mechadyne's concentric camshaft assembly to help boost power output to 600 bhp (450 kW).
In 2009, Fiat Powertrain Technologies introduced the Multiair system in Geneva Motor Show. The Multiair is a hydraulically-actuated variable valve timing system, which gives full control over valve lift and timing. The new technology will be available in Alfa Romeo MiTo starting from September 2009.[5]
In 2009, Porsche introduced an enhanced version of VarioCam Plus on its 911 GT3 including the previous variable valve timing and two stage valve lift on the intake valves but with additional variable timing of the exhaust valves.
[edit] Diesel engines
In 2010, Mitsubishi developed and started mass production of its 4N13 1.8 L DOHC I4 world's first passenger car diesel engine that features a variable valve timing system.[6][7]
Corksil
24
Jun 3, 2011 09:22 AM
Miracle
Honda Civic (2001 - 2005)
74
Feb 26, 2010 07:30 AM
leperchun1988
Jan 24, 2009 09:23 PM
prelude_93vtec
Aug 16, 2007 03:51 PM
AccordDemon
Nov 16, 2005 12:09 PM
