high rpm fluctuation
Old Nov 16, 2013 | 05:09 AM
b20vteg757's Avatar
Default high rpm fluctuation
When I'm gettin it at high rpm's the needle starts going crazy. Thought maybe something in the distributor could be lose btut checked and its all good. Any thoughts?
Old Nov 16, 2013 | 06:50 AM
motoxxxman's Avatar
Default Re: high rpm fluctuation
distributor is probably starting to fail. or your cluster is bad, or you simply have a bad or loose ground
Old Nov 16, 2013 | 07:07 AM
b20vteg757's Avatar
Well I replaced all the internals of the distributor recently includigng coil and igniter. Grounds seem good but ill double check that
Old Nov 26, 2013 | 05:57 AM
b20vteg757's Avatar
Solved the issue. It was the wire that goes from Igniter to the top of coil. . Replaced it and all is good and shift light works great
s13hero
31
Jun 17, 2016 06:43 AM
spooledex
Oct 10, 2009 12:36 AM
gnccracer20
Apr 4, 2009 08:00 PM
s2kkk
Jan 6, 2006 02:16 PM
customx_
Jun 18, 2002 11:30 PM
