Help with VTEC not engaging!!! '92 CX B18C1 swap
Old Jul 27, 2004 | 06:03 PM
Yellow Dragon's Avatar
Default Help with VTEC not engaging!!! '92 CX B18C1 swap
Okay my roommate owns my old hybrid. I did the swap and I know it was done right. Swap was done in April '01 and I haven't had any probs. Engine is a '94 B18C1 with 60k at the time. New water pump, timing belt, and fuel filter.
My roommate has bought it and hasnt' had any problems until the other day. He went to Quik Trip for gas (premium) and now NO VTEC. It was late last night, but today he drained the gas and put in BP 92 Octane. Still no luck. We checked the wires to the VTEC solenoid and everything is intact.
Obviously we checked the oil levels and that's fine.
No CEL whatsoever. What could this be? We thought maybe the fuel pump or oil pump. Wouldn't we get CEL for either of those?
Any help would be appreciated. You can send me an AOL IM at WRXRATED7 also. Please help guys. I've been messing with Subarus too long and nearly forgot how to work on Hondas!
-Todd
Old Jul 27, 2004 | 06:36 PM
Tyree's Avatar
Was the car warmed up?
Old Jul 27, 2004 | 08:57 PM
Default Re: (WatsUpDOHC)
Most definately.
Old Jul 27, 2004 | 09:01 PM
Fobtions's Avatar
Default Re: (Yellow Dragon)
test the solenoid itself.
Old Jul 27, 2004 | 09:15 PM
Humble1's Avatar
Default Re: Help with VTEC not engaging!!! '92 CX B18C1 swap (Yellow Dragon)
in my newly swap jdm b18c, i took the vtec solenoid out cleaned it good with brake or parts cleaner then replace the solenoid screen gasket and voila.vtec now finally works.give that a try after u do the other stuff.
Old Jul 27, 2004 | 11:11 PM
evillesi's Avatar
Default Re: Help with VTEC not engaging!!! '92 CX B18C1 swap (Humble1)
i have the same problem in my 99 si i havent had vtec for 3 months even when there are no codes it still doesnt work so if you figure somthing out let me know
Old Jul 29, 2004 | 10:24 AM
Default Re: Help with VTEC not engaging!!! '92 CX B18C1 swap (evillesi)
Well after looking at my Helms manual for awhile, I wondered a few things. The VTEC solenoid has two filters in it. Has anyone ever known this?! Maybe those are plugged up. We've checked all the wiring. It's crazy because it worked briefly the other day, but hasn't worked again since. Wouldn't you get a CEL if the solenoid itself went bad?
Thanks,
Todd
Old Jul 29, 2004 | 02:11 PM
If there's anyone out there that thinks they can help me out, please send me an AOL IM: WRXRATED7
It doesn't just seem like VTEC, but a loss of power overall. Could the ECU go bad? Has this ever happened to any of you? What about the oil pressure? Is it worth checking if I'm not having other probs?
Thanks,
Todd
Old Jul 29, 2004 | 02:36 PM
krazie1's Avatar
BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humble1 &raquo;</TD></TR><TR><TD CLASS="quote">in my newly swap jdm b18c, i took the vtec solenoid out cleaned it good with brake or parts cleaner then replace the solenoid screen gasket and voila.vtec now finally works.give that a try after u do the other stuff. </TD></TR></TABLE>
sounds like this to me too
as I had the same problem myself one day was fine and the next head gasket change no more VTEC
and it was that
that is where I would begin and then scratch ur head and check other stuff like the ecu
metalgear
Sep 2, 2018 08:06 PM
thecruzs2007@yahoo.com
Oct 9, 2011 11:01 PM
jvonb
Oct 24, 2006 05:14 AM
vtecb20coupe
Jan 8, 2004 07:37 AM
