help! valve adjustment on sohc vtec motor
Old Feb 14, 2003 | 11:15 AM
boot machine 5000's Avatar
Default help! valve adjustment on sohc vtec motor
need the clearance specs for a valve adjustment, thanks in advance
Old Feb 14, 2003 | 12:53 PM
Chiovnidca's Avatar
Default Re: help! valve adjustment on sohc vtec motor (Alvin)
Need year and model to give correct specs.
Old Feb 14, 2003 | 02:20 PM
Default Re: help! valve adjustment on sohc vtec motor (Chiovnidca)
2000 civic ex
Old Feb 14, 2003 | 05:32 PM
Chiovnidca's Avatar
0.18-0.22mm intake
0.23-0.27mm exaust
They should be adjusted with the engine cold.
Old Feb 18, 2003 | 11:18 AM
yee SERIOUS's Avatar
are the exhaust ones suppose to be done first and then the intake ones?
Old Feb 18, 2003 | 11:35 AM
Redline130's Avatar
Default Re: help! valve adjustment on sohc vtec motor (LiTtOGPiMp)
Either side, just do each cylinder at a time, making sure that that cylinder is at TDC (top dead center).
lowlife9
Honda Civic (2001 - 2005)
Sep 21, 2010 09:57 AM
gmacarize
May 2, 2006 08:04 PM
notguilty411
Aug 9, 2005 04:58 PM
KURUPTinc
Jul 2, 2005 06:12 PM
CptMidway
Jun 25, 2003 06:03 PM
