help me identify these cams please
Who the fack changed my title?!
i got pictures but i wanna know if any knows these specs or has even heard of them. im assuming they are type a's or type b's from blox
Specs:
INt-(lift)Reg 7.29mm VTEC- 7.42 mm
2.87in .292in
Ex- (lift)Reg 7.38mm VTEC- 8.04 mm
.290in .316in
Specs:
2.87in .292in
.290in .316in
multiply by 1.55 and thats the real spec...thats the rocker arm ratio...i got 12.4 and 11.5...but i think u got them mixed up...exhaust is the intake...the intake one has the slot for the distributor...
rocker arm ratio...google it....i cant remeneber where i got it from..but i was trying to id some cams and the numbers didnt make sense...i think the honda manual..
OK! so, i initially was gonna buy the cams for 150, and i told homeboy that i was taking a great risk buying these because i didnt know if they were even for a b series or another motor(h series or a zc dual etc) so we agreed on 130 for the set. i lucked out! these suckers are HUGE
the center 2 are the new ones
here is a stock gsr cam
and here is the comparison of intake and exhaust cams
and here are the specs i came up with measuring height and width measurements
oem intake:
width: 1.166
height:1.432
lift:0.266
oem exhaust:
width:1.172
height:1.409
lift:0.237
new cam intake:
width:1.168
height:1.480
lift:0.312
new cam exhaust:
width:1.173
height:1.558
lift:0.385
i believe this is a huge gain in lift and there might be about a 15 to 20hp increase with proper tune. but i could be wrong?
oem intake:
width: 1.166
height:1.432
lift:0.266
oem exhaust:
width:1.172
height:1.409
lift:0.237
new cam intake:
width:1.168
height:1.480
lift:0.312
new cam exhaust:
width:1.173
height:1.558
lift:0.385
no i was the buyer and he was the seller. but im trying to determine which kind of cams these are. im ALMOST positive they are blox but i could be wrong. what else would i need to measure before making my final assumption.
usualy cams have higher lift on the intake side...so yours should be easy to id...the buddy club spec 3 have bigger exhaust lift..but not by much..and all blox cams have bigger lift on intake than on the exhaust...so i ask again...did you measure them right?...are you sure that the vtec lobe on the intake(cam with slot for distributor) is 7.42mm
i only measured the vtec lobes. on both cams. i was measuring with a micrometer in inches. not mm's. or maybe i got it incorrect.
ALLOUT CL55
32
Jun 18, 2010 06:25 PM
