Help! I need an electrical genius...
Old Nov 19, 2001 | 03:45 PM
il8apex's Avatar
New User
Default Help! I need an electrical genius...
I've got a mysterious electrical leak. After I charge the battery the car will run fine for awhile. Then things start to happen: wipers slow, lights dim, radio shuts off, etc. Classic alternator symptoms. So I have the alternator tested, and it's perfect. When tested in the car, the alternator is definately charging. The wiring from the alternator to the battery checks out OK. I've pulled every fuse (radio, windows, sunroof, etc.) to check for leaks, and the same thing happens. What gives?
-Tom
Old Nov 19, 2001 | 03:57 PM
2latev8's Avatar
New User
Default Re: Help! I need an electrical genius... (il8apex)
battery maybe?? if you have a manual check the electrical load detector on you car. hope it helps
Old Nov 19, 2001 | 04:22 PM
smp534's Avatar
New User
Default Re: Help! I need an electrical genius... (2latev8)
check your PM's
[Modified by smp534, 1:22 AM 11/20/2001]
Old Nov 19, 2001 | 04:36 PM
GZR4DR's Avatar
Make sure your altrernator belt is the proper tightness. If its to loose, you can have these symtoms.
eggie75
Mar 25, 2010 04:37 PM
djrubio
Jul 18, 2009 07:41 PM
lmike6453
Jan 16, 2009 06:55 PM
EG6R
May 10, 2007 01:57 PM
EG6[B16A1]
Jun 28, 2003 09:03 AM
