HELP! H22 EG, STIFF/JERKY THROTTLE
Old Jan 11, 2006 | 12:58 AM
Terrible One's Avatar
Default HELP! H22 EG, STIFF/JERKY THROTTLE
just got this car last week, its a 93 civic hatch w/ h22a swap. when i give it gas it jerks forward, not smooth. it wont keep a steady rpm when driving, keeps accelerating. i know its got torque but this is rediculous. im guessing its a tps problem or throttle cable problem. anybody ever had the same problem?
Old Jan 11, 2006 | 09:03 AM
Default Re: HELP! H22 EG, STIFF/JERKY THROTTLE (Terrible One)
up
Old Jan 11, 2006 | 10:47 AM
bump
Old Jan 12, 2006 | 06:07 AM
old man neri's Avatar
Does your pedal feel smooth or is it sticky? If you feel reisitance and jerkyness in your pedal you might need to clean out your throttle body, they are known to gum up.
Old Jan 12, 2006 | 11:58 AM
Ruthless671's Avatar
Default Re: HELP! H22 EG, STIFF/JERKY THROTTLE (old man neri)
Make sure your throttle cable is not kinked as well. if your throttle body is sticking, clean it, but make sure you dont spray the cleaner into the TPS side. Did that one time and cause the idle to fluctuate at 900-1300
Old Jan 12, 2006 | 12:22 PM
Default Re: HELP! H22 EG, STIFF/JERKY THROTTLE (Ruthless801)
bump, thanks guy i will check that
Old Jan 12, 2006 | 06:29 PM
Old Feb 16, 2006 | 07:54 PM
hondah2b21's Avatar
what ecu do you have?
my boy use a stock p30 and it ran like $h!t but he took his car to some guy in nj. he put it on the dyno and chipped his ecu. after that he said the car ran great no more bogging.
Old Feb 16, 2006 | 09:03 PM
ek9hatch0WN3R's Avatar
Default Re: HELP! H22 EG, STIFF/JERKY THROTTLE (hondagsr21)
adjusting the tension on my throttle cable fixed this problem for me. trial and error is all i did. TIP: dont adjust too much or you'll end up with an idle at 4k rpms
shabam
Dec 9, 2007 07:52 PM
JDM H22
Sep 1, 2006 10:21 AM
JDM H22
Aug 27, 2006 06:11 PM
si0385.
Feb 3, 2006 08:19 PM
1QWKGS
Apr 3, 2005 11:52 PM
