HELP to fix CHECK ENGINE LIGHT CODES!!!!
Old Aug 6, 2009 | 05:32 AM
NiKKa NiKKy's Avatar
Default HELP to fix CHECK ENGINE LIGHT CODES!!!!
well my car is throwing out check engine lights 07 (Throttle Angle), 08 (TDC Position), 15 (Ignition Output Signal), 22 (VTEC Oil Pressure Switch), and 41 (O-2 Sensor Heater ). Could anyone tell me what i need to fix/replace to resolve all these problems? i drive a 94 integra with a 95 obd1 gsr swap in it, the car was normally a automatic ls so yea. just help me out please.
Old Aug 6, 2009 | 10:14 AM
delsolproblems's Avatar
Default Re: HELP to fix CHECK ENGINE LIGHT CODES!!!!
If everything is connected properly then you at least need a new distributor and an O2 sensor. Do NOT get a universal O2- get a direct fit. You should follow the testing procedures in a shop manual to check the listed sensors (aside from the O2) before buying a new distributor.
265Kandcounting
Dec 19, 2017 12:57 PM
jjenkins
Mar 6, 2010 08:37 PM
civicsaremean
Jun 24, 2007 08:27 AM
