Help Diagnosing Sound
It just started doing this out of nowhere.
('97 LS engine ... roughly about 35k on it) .... Car was cold, getting it ready for storage.
So I started up heard a whine (more like a whirl sound high pitched sound).
Sound coming either out of Alternator or inside the Timing Case Cover. I've never heard a sound like this even on a bad belt. So I thought it'll Idle down and work itslef out.
Took it out for a spin just in case. I can notice the damn sound (a bit faint but noticeable) at around 3k (RPM's) from either gear (1st - 5th).
So what do you guys think from experience it could be ??? Could it be the Atlernator Pulley or maybe the Water Pump bearing .....
I have never heard a sound like it before, It's like a "whirl-whine" only lasts for 2-3sec during those RPM's described in the above statement.
[Modified by Honda4CX-R, 11:38 AM 11/25/2002]
Check power steering fluid level.
It's not the A/C nor the Pulley ... The sound is eminating from T-Cover case towards the Alternator only.
It was fairly loud (that's why I was like WTF) that morning but it went away as the car warmed up and idled to normal rpm's...
Has the water pump ever been replaced?
Connect a Voltometer to the battery and run the car. What Amperage are you reading? It should be around 14. when the car is running
I've never had to change any "Honda" water-pump until around 130k or more ... no joke !!!
BTW, I've had the swap in the car for 2-Years now trouble free.
*** UPDATE ***
Decided to take car to work to see if problem any dif. Parked outside in the COLD.
Drove home and the "Whirl" noise is very noticeable w/o letting engine warm up.
Pick one A/C or ALT ???
The alternator has same tension never removed, ran fine last winter, so ???
The A/C was just installed before summer, but wouldn't I have or show signs of problems beforehand if tension wasn't set properly ?
[Modified by Honda4CX-R, 5:35 PM 11/25/2002]
i'd say check the belt tention
What is this gonna really tell us ???
So let's recap then .....
Possible causes:
1) A bad water pump.
2) The alternator bearings are bad or going alternator.
3) Or a bad air conditioning compressor Pulley ...
[Modified by Honda4CX-R, 6:24 PM 11/25/2002]
Possible causes:
*** UPDATE ***
Took partial T-Cover off .... Started up car ..... Not good, noise seems like a dry grind coming from Water Pump area .....
......... also T-Belt looks a bit slappy like ... is that normal ?
Ser1N
May 13, 2008 09:08 AM
MugenPoweredLude
Audio / Security / Video
13
Mar 7, 2003 05:42 PM
