HELP, car won't start after FULL-TUCK!
Old Aug 10, 2010 | 04:43 PM
SoFresh's Avatar
Default HELP, car won't start after FULL-TUCK!
I did a full wire tuck, brake line tuck, etc. 2000 Civic SI, deleted the charcol canister, did an in-line fuel line -6an, AEM fuel rail for now. Car is getting fuel, no leaks. Have oddessey lightweight battery in the interior.
Problem, I cannot get the car to turn over. Would this maybe be related to the alarm after the tuck? Please throw out all ideas I need to go over to check to see why its not turning over. I used a code scanner and just shows up ERROR.
Old Aug 11, 2010 | 01:50 AM
itslogz's Avatar
Default Re: HELP, car won't start after FULL-TUCK!
Getting +12v at the signal wire at the starter when you turn the key all the way? Have a friend turn it while you check. Also +12v with the key on to the battery lead to the starter?
Old Aug 11, 2010 | 02:23 AM
wellwell's Avatar
fuel pump turnin on ??? you here the starter click ??? check grounds i know when u do a tuck you get rid of wires that might not need like grounds
Jlove1993
Feb 3, 2015 09:43 AM
lif3tak3n
Jun 24, 2014 06:00 AM
98integralsB18
Apr 29, 2009 07:07 PM
superhatchbackbros
26
Apr 26, 2007 04:44 PM
junya16
Mar 1, 2003 07:30 PM
