Help b18 fully built just need rods
I have a b18c1 gsr with everything imagineable that can be done sleeved bored strked over 10 g's in motor parts and i need just one thing THE RODS. I have rods but they are too long eagle 5.531
they need to work with my eagle light weight 95mm stroke crank and my arias 84.5 mm stock stroke pistons recently i was having exospeed get me the rods i need custom made through carrillo but if anyone knows exospeed out of glendale CA they will understand why my project has been at a dead stop for the past 10 weeks which is what brought me to this forum this is my last resort. I NEED HELP does anyone know of this b18 stroker setup and what rod length i will need made please let me know!!!
This is a list of parts that ive waiting to be slap together with these damn rods i
need!
high hp axles
p72 s300 socketed ecu
mishimoto rad
2 12" slimfans
all pads + rotors
wallboro 255lph
hondata s300
underdrive pulley kit
gates blue racing timing belt
canton racing oil pan
obx valve cover
arc camseal
aebs head + main studs
darton M.I.D. sleeves
arias pistons 9.0.1 84.5mm
cometic MLS custom 84.5mm head gasket
eagle light weight stroker crank+bearin
blox throttle body 76mm
rc 1000cc injectors/0bd1 clips
turbonetics GTK550 turbo
turbosmart wastegate
peakboost hvs top mount manifold+3" dp
steel braided fuel line
steel braided turbo oil lines
hks type-1 turbo timer
aem wideband O2 sensor
aem fuel rail/filter
aem fuel press.regulator
aem HD water/ methanol injection kit
omni 4 bar map sensor
supertech valves
supertech valve guides
supertech valve seals
nitrous express 250 shot direct port kit
-Skunk2-
pro series stage 3 camshafts
pro series intake manifold/76mm bore
pro series cam gears
tuner series valve springs/T.retainers
-service-
sleeve block
bore block
port and polish pro head work
need!
high hp axles
mishimoto rad
2 12" slimfans
all pads + rotors
wallboro 255lph
hondata s300
obx valve cover
arc camseal
supertech valves
-Skunk2-
-service-
sleeve block
bore block
You actually need more than rods. Tuner springs do not work with Pro3's. Pro3's do not work with turbo. If you have 1.181 height pistons, there is a shelf rod. This looks like a wish list.
comp.height 1.185 ? once i installed the rotating assembly i turned it an the piston comes out of the deck like a half inch honestly im 19 and just dont have the skills to finish this what should i do i really want to keep the pistons an crank if anything get new rods how can i figure out exactly what size i need. i have no idea how to measure the thing someone familiar with these numbers
sumo
18
Jun 19, 2005 10:49 AM
