hello
My friend doesn't get online much, but he wanted to know if anyone had any tips on a ZC Motor in a CRX SI. He's doing turbo and he currently rebuilding the motor himself, but the pain about it is the wiring ....and what ECU would be good with the motor ....he heard a 89 integra ECU would do good....but I'm not into ZC so I wouldn't know much in that category......If you can please post me some links or tips to help my friend out. Thank you......
You can use the PR4 ECU (for the B18A) and that'll work fine. it may run a little on the rich side, but no extremely.
As for everything else, you can use the Si harness and everything. I'm not 100%, but you should be able to plug in everything as they are both OBD0 (assuming you are referring to the DOHC OBD0 motor)
heatho
Aug 13, 2008 09:32 PM
ProtegetypeR
Mar 25, 2004 03:38 PM
