headlight bulb install?
Hey this sounds silly but I was having a hell of a time last night putting in new bulbs. It didn't seem to want to work . There is some arm thing that clasps the bulb then rotates in and slides under something. I dunno, I don't know if I put them in right or not. They work but? Is there any good diagram on how that arm and bulb thing should work?
It's a 96 civic...
It's these stupid delicate parts I hate...
It's a 96 civic...
do this. place headlight in. If you look, there should be a screw in the headlight where the Wire thing goes onto. take a philips head screw driver, unscrew it a bit, not to much. Stick the side that is flat under the screw and screw it in kinda tight. Make sure that the part that has teh little U is on bottem. that goes over a plastic part on the headlight. after that it should be set. Connect headlight, place rubber back on. you good to go. If this confuses you, post up a picture of the clip and picture of where the headlight goes into and ill show you in detail. Hope this helps
