head gasket question (searched)
I feel pretty stupid even having to ask this, but I want to be sure I am going about this the right way...
I have a sleeved b16 with an 84mm bore...which would be the best headgasket for this application...b20 or custom 84mm b16/18 headgasket?
if I use the b20 headgasket, will it block the oil feed to the head for the vtec?
I have a b20, and a b16/18 headgasket sets coming in today to compare the two, but I thought I would ask as here as well to see if anyone else has run into this issue
I appreciate any insight anyone can give me, I did search, but i didn't find anything about which headgasket to use with a over bored vtec bottom end.
my first instinct is to use the b20 headgasket, but I cannot remember if it will block a oil feed/return if used on a vtec bottom end
tia for any help/info
**update**
after checking the b20 headgasket to the block, it seems the b20 will not seal an oil passage...
now my question is, where can I buy a 84mm vtec headgasket??
Modified by 92_civic at 10:17 AM 5/4/2007
**update**
ANNiHiLATORS
Nov 28, 2009 11:35 PM
blackcrx16
Feb 28, 2008 04:04 PM
